TitanBionis
- Joined
- Feb 13, 2026
- Messages
- 1
I’ve got a weird one and it’s making me feel like I’m missing something obvious. I have recessed LED wafer lights in a hallway and they started strobing randomly the other night when I flipped the switch. I turned them off, turned them back on, they were fine, then two days later it did it again and my brain immediately went to “is this a wiring issue.”
If you were called to a house for this, what’s your first move to narrow it down without swapping the whole run. Do you start at the switch and connections, check for a loose neutral upstream, isolate one wafer at a time, or suspect the dimmer or driver first. I’m not looking to do anything unsafe, I just want a sane checklist before I start replacing perfectly good lights.
