I’m dealing with a weird one and I’m trying to figure out if I bought the wrong dimmer or if the LED setup itself is the problem. The lights look totally normal at full brightness and mid range, but once I dim down near the bottom they start doing that annoying flutter flicker.
A specific moment was last night when I tried to set a low cozy level and it looked like the lights were breathing. What’s your go to way to confirm dimmer compatibility versus a driver issue, and what’s the simplest check you do before swapping parts?
