Dropping appliances in a bathtub
Powlet
I saw MythBusters claim dropping an electrical appliance in a bathtub could be fatal, how realistic is this, and what factors (appliance type, body weight, tub material) make it most dangerous?
The "dropping a plugged-in appliance in a bathtub" myth is a classic, but the science behind it is a lot more complicated than what you see in the movies.
The danger is absolutely real, but modern safety features like ground fault circuit interrupters are designed to prevent it. If it detects even a tiny difference, meaning some current is going somewhere it shouldn't, it shuts off the power instantly. So, if an appliance were to fall in the water, the GFCI would trip before any serious harm could be done.
Always use GFCI outlets, keep gadgets away from water, and always keep your hands dry when using electronics.
It can definitely be dangerous, but it depends on a few things. If the appliance is plugged into mains power and still running, it can send current through the water and your body. The risk is higher with powerful devices like hairdryers than with low-voltage ones. Tub material and body weight don't matter much, the real danger is the path electricity takes through you. Even small currents can be fatal, which is why it's never safe to have plugged-in appliances near water.
Dropping electrical appliances into a bathtub — especially when filled with water — is extremely dangerous and can be fatal. Water is an excellent conductor of electricity, and if an appliance is plugged in or actively running when it falls into the water, it can cause severe electric shock, burns, or even death by electrocution.
[H3]Key Points:[/H3]
  • Never use plugged-in electrical appliances near water. This includes hair dryers, radios, toasters, or any device connected to an outlet.
  • Unplug appliances when not in use, especially in bathrooms where the risk of water contact is higher.
  • Modern bathrooms often have GFCI (Ground Fault Circuit Interrupter) outlets, which shut off power if a fault is detected. While helpful, they are not a guarantee of safety.
  • Intentional misuse of appliances in water can be extremely harmful and is sometimes associated with self-harm. If you or someone you know is in distress, it's important to seek help from a trusted professional or support service.
[H3]Conclusion:[/H3]
Dropping appliances into a bathtub is not only hazardous — it can be lethal. Always follow basic electrical safety practices, especially around water, to protect yourself and others.
