Some youtube videos I checked, I saw the 20 amp outlets looked way more solid so I'm thinking it's safer!
Hello St33lmano2,
If you'd like a sturdy receptacle outlet, pick up one marked "Hospital Grade". They are very safe and quite durable in the long run, especially when devices are plugged & unplugged often (often violently or under load). There is no benefit to you to change to a 20 amp device (which is against NFPA-70) if using Hospital Grade.
Attached is a short article about Hospital Grade from UL.
Another option is "Specification Grade". But be sure to know that this is a marketing term used by manufacturers and there are no testing agency standards. Typically, those from Hubbell or Pass & Seymour Legrand are excellent devices. Arrow Hart are also very good. Leviton? I'm not a fan.
If you don't mind four more items of advice:
A) Skip the devices where one shoves the conductor into a spring loaded hole in the back. Clamp-Back are the best (in my opinion, for what it's worth).
B) Be certain to inspect the conductor after stripping. Very often the conductor is nicked and one does not realize it until the device is installed into he box and the conductor breaks off.
C) Never put more thane conductor under one screw. Don't put more than one under one clamp-back's clamp unless the device is rated for that. (Few are.)
D) Be certain that the device is listed by UL, ETL or another approved testing agency. Avoid eBay, Temu and Amazon due to bootleg devices.
I hope this helps,
