DerekShepherd
- Joined
- Mar 26, 2025
- Messages
- 2
I've always been under the impression that a 240v commercial grade induction cooktop wouldn't function if plugged into a 120v outlet. The other day, a friend of mine connected a 120v plug to a 240v cooktop, and surprisingly, it powered on and seemed to work fine on a standard 15A breaker. At 120v, it draws about 10 amps, so in theory, it's within limits. I do understand that 240v is essentially two 120v legs with a neutral and ground, whereas 120v setups have one hot leg, neutral, and ground. my friend said he had an idea of the setup from something he saw online and I know this and a part of me knows isn't how it's supposed to work so I feel weird about it but apart from the increased amp draw, its pretty functional
Is there a real risk of damaging the circuit or causing failure in the long run?
