Trying to figure out if my breaker is aging or if the cold is messing with things
TriforceHylia
I might be overthinking it but the breaker on one of my circuits in Iowa has been acting weird since the cold rolled in. It is not tripping constantly but it clicks off at random moments that never used to happen last month. I am stuck wondering if the breaker is just getting old or if the shift in temperature is messing with something in the panel. The house is from the nineties so nothing shocks me anymore when it comes to aging parts. Just feels strange that everything started right when November got colder. Anyone else seeing the same thing or should I just replace the breaker and be done with it?
I’ve only been licensed a short while, but I’ve seen cold weather make older breakers act a little touchy. Not full trips, just those random clicks that make you stop and stare at the panel. If the house is from the nineties, it wouldn’t surprise me if the breaker is just getting tired. Does it reset clean every time or does it feel a little stiff when you flip it back?
The beaker might simply be getting weak. Is it used near its trip threshold? What brand and model is it? Some go bad sooner than others.
Second question: Is the load center in an environment where it is exposed to chlorine, such as a laundry area where bleach is used? Chlorine fumes can damage, thus weaken, circuit breakers' springs.
Temperature?
I've found the opposite of what VaatiWind mentioned for circuit breakers. When the temperature goes down, resistance load follows. Resistance circuits operating close to the circuit breaker's trip threshold won't trip as quickly as they will when the conductors or utilization item is in a hot environment.
A follow-up is to ask if the load center is outdoors. When the temperature drops, condensation in the breaker can cause tripping. Condensation that freezes can cause tripping and damage.
Hope The Problem Resolves!
When a breaker only started acting up after the temperatures dropped, it is worth checking both the load and the condition of the breaker before replacing anything. Cold weather can tighten connections or highlight ones that were already a little loose. It might help to see if the trip lines up with heaters, fans, or anything cycling more often this month. Have you noticed if the panel itself feels colder than usual when it happens?
