Scotland residential alters
peanuts25
Moved to Scotland a few moths ago and I've been wanting to remove this socket that never gets used, though im puzzled as to how much modifications I can make to my flat. Read about this part P though based on my understanding it doesnt really apply here. Can anyone shed light on this? much appreciated
I'm sure it's not much of a difference, bcs (I assumed) it's a rental apartment or flat. You need to contact the owner or landlord if you want to change anything there
Part P is an England and Wales thing, def initely so I dont think it should apply in Scotland, not sure though but I think it's more about following the general building regs and the IET wiring regs. If you're a tenant, check your lease first, some landlords are strict about any electrical changes, even minor ones but if you do own the flat, you're usually fine to remove a socket as long as the work is done safely and properly terminated.
You're right it doesn't apply in Scotland. Up here the rules fall under the Building Standards, and the expectation is that electrical work is done to BS 7671. If you're just taking out a socket and making the circuit safe, it's not notifiable, but best practice is to have a competent electrician check it over so you're covered
You can isolate and remove it safely, but any modifications to the fixed wiring in a flat can be tricky due to lease or building regulations, contact a qualified electrician and Part P mainly governs safety, so it might still apply depending on how you do it
They are right! Afaik, Scotland does not have the self certification scheme tied to Part P. This means it is up to the homeowner to show that the work complies with the regulations. But if you are unsure it is better to check with your local council for confirmation before you start removing that socket.
