Electrician workwear recommendations for safety
WireWhisperer
Member
I'm hunting for some good workwear for electricians, really focusing on safety. What kind of gear do you all use, especially when dealing with live circuits? Are there any brands or specific items that you absolutely trust for both comfort and protection? Appreciate the tips
When dealing with live circuits, arc rated clothing is key. you can find some brands available online. Layering clothing can also add protection. Stay safe!
Are you mainly working indoors or out in the field? I've found certain gear works better depending on whether you're crawling through attics or working around switchgear in rough weather
Anything that's flame and arc resistant is something you'll want to go for. The gloves need to be rubber and the shoes must be well insulated. As for brands you have tons to choose from, so go for the ones that have the right certifications and you'll be good to go
Anyone know where I could find 2 or 3course on practice testing for 2391/5
Kinda missed the topic here my man
Hi WireWisper,
Best Plan: Work de-energized only.
If Not Possible:
Check NFPA 70-E.
Its sole purpose is electrical workplace safety. There are lots of words about work wear.
Also note that not all rubber gloves are suitable. All rubber soles shoes definitely are not- only some are. All plastic hard hats are not necessarily safe. All flash helmets and goggles are not necessarily suitable.
I worked as a linesman years ago, usually on 310,000 volt transmission tower lines. Our work wear was very specifically designed, tested and certified. Many sources of certified gear are on line and in stores. Grianger and Zoro (a Grianger daughter company) have a good selection.
Stay away from imported gear with certifications that may be faked. Go name brand only.
AND...
Test your equipment before every job. Purchase an inexpensive meg-ohm meter for quick testing. (Match the tester voltage to the range you're working on.) I am an electrician usually working to 13,200 volts maximum, but I test my gear daily when working live at any voltage. It's required in many job sites.
AND-
Do Not Trust Rubber Gloves & Plastic Handle Tools Unless Listed As Insulating!
