Dual input relay for shared extractor fan control across 2 independent circuits
I'm setting up a shared extractor fan controlled by two independent switched live lighting circuits (240V AC) but want to avoid double pole switches due to cost and complexity. A dual input relay seems like the best solution can anyone recommend specific models, wiring tips, or safety considerations, especially if the circuits are on different phases?
You should use a dual-input relay rated for 240V ac and the fan's current for example schneider Electric or honeywell q5700a to control the fan from two switched live circuits on different phases, to ensure proper neutral handling. And to better be safe than sorry, use a double pole isolator, rcd protection, and follow wiring color codes to avoid cross-phase issues and ensure correct operation.
Thanks for the thorough input. Using a relay like the Q5700A makes sense. Have you had better reliability with one brand over the other for long term use?
That sounds like a solid plan using a dual-input relay setup. I've noticed that the Q5700A performs really well in setups like yours. Both Schneider and Honeywell are reliable options, but from what I've seen, Schneider usually has the upper hand when it comes to longevity and finding replacement parts. Have you figured out how you're going to manage the neutral path and labeling for future service? It's definitely wise to have a plan for mixed circuits.
Thanks for the follow up. The advice here was on point. I went with the Schneider relay and got it all wired up last week. The neutral is pulled from the fan's supply circuit and I made sure to label all the connections clearly to prevent any future issues.
