Can I use the same fuse for fridge and coffeemaker?
KrispyKreme
My husband I are doing a little remodeling of the kitchen. I have 20-amp fuse where the coffeemaker is usually plugged. Can I use this for the fridge instead? Or is it a little too much?
You're totally fine using a 20 amp circuit for a fridge, especially if it's a modern energy efficient one. In fact, most fridges prefer a dedicated 15 or 20 amp circuit, so make sure the fridge is the only major appliance on that line, also, a little side note, don't run the coffeemaker or microwave there too, or you might trip it.
I cannot stress this enough! Refrigerators draw a good amount of power so it should ideally have its own dedicated circuit, or you're risking damaging other appliances or worse, starting a fire!
Yes, as long as the refrigerator is the only device on the circuit, you can run it off of that 20A outlet without any issues. When they first start up, refrigerators typically draw 3–6A, and occasionaly 10–15A. A 20A breaker handles up to 16A continuous, so you're good
However, it might trip if you have other devices plugged in. To be honest, giving the refrigerator its own line is ideal during a remodel. You'll be grateful in the future
